Automatic centerlines and centermarks are not immediately showing up when set for a view
mike_niemotka
mike_niemotka
Automatic centerlines / centermarks are not always immediately showing up when set for a view.  In some cases, I have to deselect the automatic option, and then re-select to make them show up.  Is this a known bug?
Pradipio
Autodesk Support
Autodesk Support
Hi @mike_niemotka,
Thanks for posting to the Fusion 360 Forum.
Are you using any Template to create your drawing?
or you are getting this issue in the default drawing sheet?
THANKS
Pradip Mistry
”Community
mike_niemotka
I saw it without any template
