I like the automatic hole note feature, especially for counterbore and countersinks, as it helps a lot with not having to manually add the symbols. I was wondering if I was doing something wrong or not, but I noticed the hole notes when added to NOT have the leader arrowhead rotate around as you go to place the note, so that it would be pointing toward the center of the hole, just like the leader does if you are dimensioning a radius or hole manually. Hope that makes sense, I think it should act the same.
