Autodesk survey!!!!!!!!!!!!!!
Message 1 of 34
Enough already, I have been getting this stupid survey pop up box for weeks now and every time I take it the same box pops up.
Replies (33)
Message 2 of 34
brianrepp
Hi @Anonymous - do you have a screenshot of the initial survey prompt you're mentioning?  Want to make sure we're looking at the correct one.
How many times a week would you say you're getting the prompt?  Are you changing networks or computers or always on the same machine/network?
~Brian
Message 3 of 34
PhilProcarioJr
@brianrepp
Same machine, same network and I see it at least 10 to 20 times a day.
If I open forums I see it, if I switch to cam forums I see it, if I switch to idea station I see it, if I close out my browser and return I see it......
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 4 of 34
brianrepp
Yikes, no good.  Thanks for confirming @PhilProcarioJr.
Message 5 of 34
What Phil said.
Message 6 of 34
PhilProcarioJr
@brianrepp
It might be because I use incognito mode in my browser. I haven't had time to test that though...
Phil Procario Jr.
Message 7 of 34
brianrepp
@PhilProcarioJr - ahh, that's good to know.  When/if you have time, please let me know if you still see it when in normal browsing mode.
@Anonymous - are you in incognito or a private browsing mode?
Message 8 of 34
No incognito or private browsing on my end.
Message 9 of 34
Guess what just popped up?
Message 10 of 34
brianrepp
I can imagine how frustrating that is - thanks for reporting, i've escalated.
Message 11 of 34
PhilProcarioJr
@brianrepp
Yeah it doesn't matter which mode I am in.
Phil Procario Jr.
Message 12 of 34
brianrepp
Hey @Anonymous - the team is working on improving the programming of when the survey pops up, but would you mind trying one thing?  After closer investigating of your screenshot, we noticed you have the ZenMate privacy plugin enabled, which may be causing some of the problems you're seeing, would you mind disabling or adding our site to your safe list to see if it stops the constant survey prompting?
Message 13 of 34
Hi Brian, I cannot find the plugin you are talking about and it’s not listed in the Mozilla plugin list?
Message 14 of 34
brianrepp
@Anonymous - I believe it is this one?  Let me know if not.
Message 15 of 34
TrippyLighting
I see this very rarely, on mac OS (still on El Capitan) and Safari. Maybe once a week.
Even when I check it rom work (shhhh. I am  not supposed to, but can't help it 😉 on a Windows machine with IE I very rarely see it.
Message 16 of 34
LMD001
@brianrepp
Hello Brian,
On macOS Sierra and Chrome and like Peter, I very rarely see the survey popup.
Best regards,
Ludo
Message 17 of 34
Hi Brian,
that icon is from the inbuilt Mozilla security tracking system and it has been indicating this site is not secure for a week now?
I used to get the padlock icon when visiting this forum but that has stopped, on my Linux machine and my other Win10 machine I get the padlock with a yellow warning triangle.
The security of this site is a worry; I did raise the issue the other day but did not get a response from any employees.
All other sites are coming up with a padlock and a secure connection, this forum is the only one that is not?
While replying to you guess what popped up!!!!
Message 18 of 34
brianrepp
Hey @Anonymous - I'm going to have someone from the Web team reach out to see if they can help troubleshoot your particular case re: survey prompts.
As for HTTP vs HTTPS, have you manually tried adding "HTTPS" to your URL line, which would put you into secure browsing mode?  I'm investigating why our notification email links are pointing users into non-secure HTTP.
Message 19 of 34
Hi Brian,
if I go to my Autodesk account I get the secure connection and if I go to my Fusion home hub where my projects are stored I get a secure connection.
If I click the help menu while in Fusion 360 and choose Community Forum I still get the unsecured site, I tried adding the letters manually and the screen shot is what happened.
Message 20 of 34
stephen.gibbsDCU35
Hello there, @Cx2, my name is Stephen and I work with the Autodesk instance of the Qualtrics platform, which hosts most surveys you'll see on Autodesk websites. I've been reading your posts with great interest as we definitely want to prevent this type of survey behavior in the future.
May I ask a few clarifying questions to better understand the problem? First, when your browser goes into protected mode because it reads the forum as an unsafe site, what do you see under Menu --> Options --> Privacy? Is it set to "Remember History", "Never Remember History", or "use Custom Settings for History"?
Second, if it is "Use Custom Settings for History", is the box beside "Accept Cookies from Sites" checked? If it is checked, is the dropdown beside "Accept Third-Party Cookies" set to "Never"? (As seen here ).
My working hypothesis is that the security settings inside Firefox are preventing cookies from being stored by Qualtrics because it believes the site to be unsafe, disabling our mechanism preventing repeat display. Thanks!
