AutoDesk MeshMixer and Fusion 360 Interfacing
I am currently creating an assembly that is made of three parts.
A center spine cut from Fusion 360.
Two 3D Contours Created by MeshMixer and cut with Vectric Cut3D.
The two 3D contours are mesh parts with too many facets to be manipulated with Fusion 360.
I cannot find an easy way to get the Zero of the parts coming from MeshMixer and the Zero from the part coming from Fusion 360 to align.
I am currently able to place this part using a cut file from Vectric Cut3D, Excel and DesignCad3D.
Has anyone developed an easy way to align the Zeros of the two AutoDesk products?
Allan Steinkuhl
innovatenate
Autodesk Support
Autodesk Support
If you insert the mesh bodies into components, you could use the align command to align the origins (assuming the mesh bodies are being inserted into the components in the relative positions to the origin. Check out the screencast below for more detail on how to accomplish this.
I hope that helps!
Nathan Chandler
Principal Specialist
