Change project moderator
I cannot find this long awaited feature, of changing the moderator, too handover a project.
How can this be done or by when will we have this feature?
Pavel_Holecek
Hello Bjoern,
in classic Fusion account is not possible to change Project moderator permissions. Owner of the account is moderator for each Projects.
If you have Business Hub (team Hub) account then you have available an administration where is possible to add moderator permission to other Team members.
Regards
Pavel Holecek
Autodesk QA team
Hi Pavel,
We have a Subscription account with multiple licenses and would like to use the possibility of the team hub, but I simply cant findout how with the new interface.
Pavel_Holecek
Hi Bjoern,
I will forward your request to our A360 team they will contact you.
Regards
I attached a link from A360  Help where is possible to get this account : http://help.autodesk.com/view/ADSK360/ENU/?guid=GUID-3E9E3C69-4D7E-4361-9477-7F21DFB84215
there is possible to sign up to A360 Team and try this new account.
Let me know if you need more info
Pavel Holecek
Autodesk QA team
prashant.reddy
Hi Bjoern,
Once you start using team hub, you can follow this help guide to change the project admin. http://help.autodesk.com/cloudhelp/ENU/Autodesk-360-New/files/GUID-4C7FE632-511A-4E9C-A9F7-81F2CBDFB...
Our records indicate that you are now using the "classic" Fusion account as Pavel referred above. I will get our sales team to get in touch with you to create a team hub and guide you through the process of using it.
-Prashant
Thank you, looking forward to hear from the sales team.
