Autodesk Fusion 360
Autodesk Fusion 360
해당 사항 없음
1,692 조회수
12 답변
1/13 메시지
Autodesk Fusion 360
해당 사항 없음
I have been using AutoCAD Mechanical with Thermal Desktop for the last 10 years. I'm now using Autodesk Fusion 360 and the learning curve is quite a bit steeper than AutoCAD Mechanical. I'm  trying to take three 40' shipping containers and weld them together. I have a Solid Works model of a 40' shipping container, but I have not been able to create 3 instances of the container. I tried creating 3 components and copying the body parts into the 3 components, but all of the body parts have the same body number. I want to delete the common interior walls, but when I delete an internal wall, I delete all of the panels on that side of the container, so the exterior walls get deleted too. I tried following the tutorials and uploading/importing as described, but I just cannot get it to work.
수락된 솔루션(2)
1,693 조회수
12 답변
답변 (12)
2/13 메시지
TrippyLighting
수락된 솔루션
Here is a video that explains the effects of copying and pasting components and bodies in Fusion 360:
3/13 메시지
해당 사항 없음
수락된 솔루션
Thank you! That video was hugely helpful.
Kevin
4/13 메시지
해당 사항 없음
My Autodesk Fusion 360 is very broken and no-one knows how to fix it, pls help!! I have weird Ghosts that don't go away when I try to delete them.
5/13 메시지
TrippyLighting
Please share your design so we can Analyse this. I am pretty sure Your Fui0sn 360 is not broken.
6/13 메시지
chrisplyler
This thread is for answering the issues posted by @Anonymous and you should start a new thread for your issue.
7/13 메시지
해당 사항 없음
I want help!!!!!
8/13 메시지
TrippyLighting
In that case, as suggested, create a new thread in the support forum and share your design.
9/13 메시지
chrisplyler
@Anonymouswrote:
I want help!!!!!
I like turtles!!!!!
10/13 메시지
jeff_strater
Yes, please do create a new thread.  It is confusing to everyone when people combine topics in a single forum thread.
And please share your sketch, as everyone is suggesting.  Very little debugging or help can be offered with just an image.
However, having said that, your "ghosts" look like sketches that are visible.  You can just turn those sketches off with the light bulb icon beside the sketch.
Jeff Strater
Engineering Director
11/13 메시지
해당 사항 없음
This is my first time using the forum thing so I am a bit new to it, how do I create a thread?
And I have tried the lightbulb thing, it does not work
12/13 메시지
해당 사항 없음
Anyone there?
13/13 메시지
chrisplyler
Are you new to navigating websites?
Look further up towards the top and right side of this page. See the orange colored links for Back to Fusion 360 Category or All Forums? Click on one of them. Then navigate to the front page for this particular forum, which is called, Fusion 360 Design, Validate & Document. Find a link or button on that page that looks like it might let you post something. Click on that link or button and see what happens.
