Autodesk Desktop connector fails to display thumbnails
Bunga777
Mentor Mentor
Message 1 of 11
Bunga777
I heard that an application called Autodesk Desktop connector can manage Fusion360 files on Windows 10. So I immediately installed it.
I think it is a great application that allows you to synchronize with Fusion360 projects and manipulate files on Windows 10 Explorer.
However, as you can see in the attached image, half of the thumbnails are not displayed.
Deleting the Windows thumbnail cache did not change this.
As a test, I tried installing it on another PC, but the result was still the same.
When I contacted support, they replied that the thumbnail display is a Windows function, so it is not an inconvenience on the application side. However, since the behavior is the same on other PCs, I am wondering if the problem is on the application side. I am wondering.
Is there anyone in this forum who is working with this application and is experiencing the same behavior?
Also, any clues as to how to solve the problem?
Replies (10)
Message 2 of 11
lucasliraAU
Hi, @Bunga777
Very interesting, I didn't know about this file preview feature, this is very interesting to get a quick preview of the files, who knows, in the future this could be an implementation of Fusion 360 itself, not if that would be possible, what is the name of this application I can do an install and perform some ski tests on Win11.
Greetings friend!
Lucas Lira - Fusion 360 Technologies, Design and Applications - Autodesk Hub Diamond
Direct contact at: https://www.linkedin.com/in/lucaslirasantos/
VEX Robotics Engineering in Brazil - https://www.vexforum.com/u/lucas_lira/summary
Main Researcher and Technology Applications in Nerd Factory - https://www.fabricadenerdes.com/
Message 3 of 11
Bunga777
Hi, @lucasliraAU
It's Autodesk Desktop connector.
You can download it here.
https://knowledge.autodesk.com/support/desktop-connector/learn-explore/caas/CloudHelp/cloudhelp/ENU/...
I would be happy for you to try the operation.
If it works as expected, I'm sure it will be quite useful.
I wonder why Autodesk doesn't push this application more.
Message 4 of 11
lucasliraAU
@Bunga777
I'll run the installation, and I'll come back here to bring you information about the functionality on my machine.
Message 5 of 11
lucasliraAU
Well, I installed the APP on Win11 but I was not successful, not even opening the application is possible, it even appears in the task manager but nothing appears on the desktop.
The only thing I can access is through the running application icons but the screen remains completely white.
Message 6 of 11
rushabhthakkar_910
@lucasliraAU, Same here..!!
rushabhthakkar_910_0-1670952178843.png rushabhthakkar_910_1-1670952194967.png
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
Message 7 of 11
lucasliraAU
@rushabhthakkar_910
Fairly, perhaps it is no longer a functional tool for Win10 and 11 operating systems.
Is there any other alternative that can fulfill this quick file preview function?
Message 8 of 11
rushabhthakkar_910
@lucasliraAU, Go where this is stored.
Once you open Desktop connector, it will open in background. And you won't see it. But it is visible here..!!
You will See options like Fusion, Drive here..!!
And once you exit Desktop connector, the options visible in this PC will also go.
Thanks and Regards,
Rushabh Thakkar.
Message 9 of 11
Bunga777
Thanks for the verification.
It's odd that it doesn't work on Windows 11.
Here is a different page, but I believe it is the latest release notes for this application.
https://help.autodesk.com/view/CONNECT/ENU/?guid=GUID-03D59AAD-65B0-45E3-84F2-A12AAA5BB267
It says here that of course Windows 11 is supported.
Why is it not working .......
@rushabhthakkar_910
Even with the image you pasted, I still don't see all the thumbnails.
I still feel that this is an inconvenience on the part of the software.
Message 10 of 11
rushabhthakkar_910
@Bunga777, Yes a few Thumbnails are not loading..!!
Thanks and Regards,
Rushabh Thakkar.
Message 11 of 11
Bunga777
I have been in contact with support and have had this confirmed by Autodesk.
I hope the developers will improve this as soon as possible.
Thank you all for your cooperation.
