- Mute
- Permalink
- Report
I heard that an application called Autodesk Desktop connector can manage Fusion360 files on Windows 10. So I immediately installed it.
I think it is a great application that allows you to synchronize with Fusion360 projects and manipulate files on Windows 10 Explorer.
However, as you can see in the attached image, half of the thumbnails are not displayed.
Deleting the Windows thumbnail cache did not change this.
As a test, I tried installing it on another PC, but the result was still the same.
When I contacted support, they replied that the thumbnail display is a Windows function, so it is not an inconvenience on the application side. However, since the behavior is the same on other PCs, I am wondering if the problem is on the application side. I am wondering.
Is there anyone in this forum who is working with this application and is experiencing the same behavior?
Also, any clues as to how to solve the problem?
