Auto Trace System
Auto Trace System
Message 1 of 11
Auto Trace System
Hey everyone,
I was trying out Fusion 360 to see if I should transition over from Solidworks. The tool I use for my work and for my friends was an autotrace feature. I have been looking around Fusion 360 and I can't seem to find this feature. Is this option available on Fusion or would I have to sketch by using splines.
Thank you
Dan
Replies (10)
Message 2 of 11
Beyondforce
Hi @Anonymous,
Welcome to Fusion 360.
I'm not quite sure what do you mean by "Auto Trace", but if you could describe or create a screencast of what is it you are trying to do, it will be much easier to help you.
Cheers / Ben
Check out my YouTube channel: Fusion 360: Newbies+
Ben Korez
Fusion 360 NewbiesPlus
Gript.app
| YouTube
Message 3 of 11
jiang_peng
Is the auto-trace converting bitmap boundary to curves? We do not have the feature. Probably you can use some other applications to convert the bitmap to svg file and import the svg to the sketch.
Message 4 of 11
TheCADWhisperer
@Beyondforce wrote:
I'm not quite sure what do you mean by "Auto Trace", but if you could describe or create a screencast ....
Here is a YouTube video.
Message 5 of 11
Apologies to the late message. I have linked a video from youtube from someone using the autotrace system on Solidworks. Tried to cast of my PC but it crashes my entire system.
https://youtu.be/yqhfCc0fbEQ?t=30s
I could do a conversion from solidworks and convert it to .svg then .svg to sketch from what someone else has mentioned. But I wanted to do all off the work on autodesk instead of relying on solidworks as well.
Thank you
Message 6 of 11
Beyondforce
Maybe this could help:
https://www.lifewire.com/turn-2d-image-into-3d-model-2293
Ben Korez
Gript.app
| YouTube
Message 7 of 11
PhilProcarioJr
@Anonymous
Use Inkscape to make your SVG, it's very fast and very easy and you will have complete control over accuracy and look. Best of all Inkscape is free.
I can make a video if you need one.
Phil Procario Jr.
Owner, Laser & CNC Creations
Message 8 of 11
@PhilProcarioJr
I don't know about anyone else, but if you don't mind I would love to see a video of how you do that.
Thanks!
Message 9 of 11
PhilProcarioJr
@Anonymous
Do you have an image you would like to see done?
Phil Procario Jr.
Message 10 of 11
@PhilProcarioJr
I did not have any image I wanted to see done, but thanks for asking and thanks for the video, very helpful.
Message 11 of 11
jo3lsantiago
Community Visitor
Community Visitor
Thank you for your help. This method is awesome
