Auto Save issue
Auto Save issue
Auto Save issue
Few hours of work on this, fusion crashed (have the crash log)  with a recent auto save about 10 mins before the crash.
The autosave window popped up when i first re-opened Fusion again but i cannot access this again, how can I access this dialogue box once it has disappeared?
Do these autosaves get stored locally? if so how can i load this up to the most recent version pre crash.
James.Youmatz
Autodesk Support
Autodesk Support
Hi @Anonymous,
You can access your recovery files in the File menu and that should allow you to restore back to right before the crash. Also, if the document was auto-saving, then the file you open from your data panel should be the most recent save. You can also check this by going into offline mode (click your name in the top-right corner of Fusion 360 and then select Work Offline and browse your data panel) to see what the last locally cached version of your file is.
James Youmatz
Product Insights Specialist for Fusion 360, Simulation, Generative Design
