Add/Create non standard thread via thread wizzard
kshea9RNL8
kshea9RNL8
The diameter of modeled shaft does not coincide with standard threads specs and the create thread wizard does not list the needed thread diameter, pitch or form (UNJ) is there a way to add new custom threads to the wizard?
Thank you for any advice.
Ken
brianrepp
@kshea9RNL8 - by chance did you come across this thread with some suggestions during your search?
kshea9RNL8
No I did not, I'll have a look see.
kshea9RNL8
That method took care of the modeling to size issue but offers no way to change the thread form to UNJ, which in the end the cutter will take care of anyway, the modeling of the threads and TPI to a non standard size  is sufficient, it isn't a solution but a work around and plenty good enough for now 🙂
