- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I feel like I must be missing something simple here, because I feel like this shouldn't be this difficult. I am attempting to create an incline that runs along a curved shape, but the thing that none of the solutions I've found online doesn't address is that the endpoint of the incline in my scenario is a curve, not a straight line / plane, which means I cannot just do a loft from one to the other.
This article suggests that you should be able to select an edge or vertex to use as a loft profile??? I've never been able to do that here, and suspect that if I could, that would address my needs, as I'd be able to just select the starting segment and end segment arc as the loft profiles, and then use the curves as guide rails.
I'm sorry if the answer is obvious, but I really am just not seeing it. I thought that maybe I could just use two sketches and loft between them, one that includes the curved segment and the circle on the right side at the base, and the second sketch that just includes the circle at the height where I want it to end, but that produces some bizarre results that I didn't see any way of cleaning up to be what I wanted, because pretty much nothing here is planar. (The results of using these as profiles for a loft are also inconsistent - sometimes it gives me a strange stretched out shape, sometimes it literally does nothing after performing the exact same steps.)
Base profile
at base height
Loft profile
at loft height
If anybody has any suggestions, please let me know! It really seems like the issue is that I'm trying to end at the circle/cylinder rather than a straight planar surface, and I just can't figure out how to deal with it.
