Assembly Problems
Assembly Problems
KrownCNC
Assembly Problems
KrownCNC
I have a sheet metal assembly I'm working on and I'm 99% sure I loused it up.  I can't open the parts individually anymore, and when I change the floor to 14GA it's still stuck on 18GA (says 14, but the material doesn't change from 0.049 to 0.0757).
What did I do and how do I save without having to re-do it, again?
FILE LINK: https://a360.co/43YBruy
jhackney1972
Take a look at this model correction.  Since it is a F3Z file, you may want to Upload it to a new Folder to prevent duplication of parts.  Model is attached.  I had to ZIP to for the Forum to accept the file.
By the way, your 14 GA rule states the thickness of 0.0747 not 0.0757 you put in your Forum post.
Here is where you messed up the Floor sheet metal thickness.
John Hackney, Retired
