Can you create balloons with multiple arrows?
alex_cayley
alex_cayley
How do you add multiple arrows to the same balloon, in cases where you might have lots of the same component in an assembly drawing. In solidworks this can easily be done by holding the CTRL key and dragging the end of the balloon arrow, this doesn't seem to be the case in Fusion. Any way to actually do this?
https://cadbooster.com/wp-content/uploads/2019/05/039-016-how-to-add-multiple-leaders-to-balloons-30...
jhackney1972
You can use the "Leader" command inside the Drawing Sketch environment.  The Animated GIF below will show this process.  It is not perfect.  Make sure you Balloon is in the right place before placing as the sketch arrow is not sensitive to a change of Balloon position.
If this answers your question, please select the "Accept Solution" on my post. If you need further help, please ask.
John Hackney, Retired
