- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
since I'm working on an assembly of a machine part which contains shelled components, my daily schedule is becoming a mess.
The assy contains between 50-100parts, and even when i turn of 90% of the parts, making an edit on whatever component in it will give me a good coffee break. Which is nice, but after 2 coffees and 2 minor chamfer changes later I would like a faster workflow in order to make it home in time.
I would like to share the file in confidence, so you can take a look at improvements i can make on editing the design.
I'm working on a HP Z-Book 15u, with i7 and 16gb of ram, solid state disk... etc. so not an under-designed machine for this kind of assembly.
Most of the components are related to each other. although not always that much.. but a minor change on something irrelevant can blow op the entire machine/part. How to prevent this sensitivity?
Right now, it is like fixing thing again and again, and after 2 weeks of making changes... there are a ton of unclear changes, added extrusions, removed faces... not really beautiful of I would have to share this with a co-worker.
By the way, I have the impression Fusion is continuously making me wait for an Auto-save action, while he should do this once every 5 minutes. maybe it's because he's making me wait 4 minutes for every feature edit, but this starts to be annoying as well. Still I don't want to risk putting it at larger time intervals since fusion is crashing from the moment it starts turtelling and I have the balls to click the mouse again.. I'm a bit in a dilemma over here 🙂
