assembly meshing error
ac27879EJYJ
ac27879EJYJ
many errors on interior faces
TheCADWhisperer
@ac27879EJYJ
It is best to keep a discussion within a single thread...
Meshing error - Autodesk Community
You have relatively extreme aspect ratio components (long skinny parts)
and thin feature parts (the brackets).
It would probably be best to do the analysis in a program that used Beam Elements rather than tetrahedral mesh elements.
(Or you might be able to use Structural Buckling Analysis.)
TheCADWhisperer
@ac27879EJYJ
For a tetrahedral mesh it would probably be better if you suppressed these grooves.
Also, the center of the beams does not look correct.
ac27879EJYJ
What exactly do you mean when you say the center beams don't look correct?
TheCADWhisperer
