Change plan
Change plan
fitcast3D
Change plan
fitcast3D
Hello fusionists!
I entered the wrong plane in a file and would like to modify it. Redefining the planes of all the sketches is not possible. Is it possible to rotate the bodies and sketches 90°? If so, how can I do this? Do you have any other tips?
Thanks in advance!
g-andresen
Please share the file and explain which sketches and bodies are involved and how they are to be changed.
günther
fitcast3D
Thanks for your fast answer. I would like to turn the whole project on the XY plan.
g-andresen
I don't see why everything has to be arranged on a different plane.
But you could save it, insert it into a new design, rotate it and remove the link.
günther
fitcast3D
I would like the plan to be the same between fusion and the printing plate in meshmixer. I tried the video you sent me but it doesn't change anything I still have this problem as in the attached image.
Do you have a solutions ?
hfcandrew
Your issue is actually with Meshmixer.
File > Preferences > File (Flip Z-Y axis on import)
What you are making anyways? Looks like some sort of a 'foot levelers' style semi-custom type of orthotic insole.
