- Mute
- Permalink
- Report
Attached tray is 450 depth in one corner, 475 depth in 2 diagonal corners and 500 depth in corner opposite the 450 corner.
I have worked out how to create a plane using 3 points.
I can orient to this plane using align
To fix the base into the assembly I have used Rigid group.
Is there a way to create a joint but then orient to a plane or something similar that doesn't need me to zoom in to create a model with a 'best fit' that will be a few microns out.
I have attached the drawing for others to see. Below is the asymetrical 'frame and base i want to join
