Assembly issues. - Multiple slider joint interaction, and aligning radial holes to slots/holes.
sunderlandjoe
Message 1 of 9
sunderlandjoe
Anyone have some insight on why the slider I have in the attached file would not work? It has no travel limits on the radial movement and this needs multiple joints to function. Edit: Quick note when creating the joints and animating it, the motion is correct, it's only in tandem they don't work.
Also side question, how does one align a bolt hole in a radial part to the centre of a slot, or another bolt hole around a part without conflicting joints or using as-builts? In Inventor you can just use constraints to do it and it works great.
Replies (8)
Message 2 of 9
jhackney1972
Are the sliding tabs, with the T-shaped end suppose to engage and move with the collar containing the matching T-notch?
John Hackney, Retired
Message 3 of 9
sunderlandjoe
Yes.
Message 4 of 9
jhackney1972
If that is the case, the problem joint is not needed but some Motion Links are needed.  I hope I am understanding what you are trying for.  Model attached.
Edit: Thinking on your second question.
Message 5 of 9
sunderlandjoe
Aha, yes that is exactly what I'm trying to achieve.
Can you educate me, and/or even just show me what you did to achieve that?
EDIT: Never mind - found the attachment I missed the part where you said it was attached ha.
Message 6 of 9
jhackney1972
I only did one Tab, you can repeat for the rest.  If this solves your question, please remember to "Accept Solution" or ask further questions.
Message 7 of 9
jhackney1972
Can you create a quick model to demonstrate what exactly you are looking for here?
Message 8 of 9
sunderlandjoe
In that same part these two highlighted areas.
If I create a cylindrical joint then want to align the set screw to the holes on the right I get a conflicting joint.
Or the one in the slot I don't even have a good way to do it.
Message 9 of 9
jhackney1972
I had to guess at the set screw size since the component is not detailed in this model.  I hope I am understanding your question.  Model is attached and a couple of Screen Captures.
