Assembling bevel gears
JetForMe
JetForMe
I have CAD for a bevel gear pair (1:3 ratio). Their origin is conveniently shared, so they're in the right position when their origins are coincident.
What I want to do now is assemble them with a relationship such that they rotate with the proper ratio. I think that's possible from something I saw, but I'm not sure how to do it. Can anyone point me to a tutorial, or perhaps just show me how? For reference, I added STEP models of the gears.
Thanks!
MacBook Pro, PCNC1100 Series 3, Slant-PRO 15L Lathe, Custom AvidCNC-based 4x9' CNC Router w/24k 4.5 kW HSD Spindle & Teknic SDSK Servos
@JetForMe
First, you have to position each components with a revolute joint. I assume you know how to do this.
Second, you can link two joints with "Motion Link", see: https://knowledge.autodesk.com/support/fusion-360/learn-explore/caas/CloudHelp/cloudhelp/ENU/Fusion-...
For example you can define the ratio: "if one joint/component is rotated by 3° then the other should be rotated by 9°".
You can even create a link between translational joints (slider) and rotational joints (revolute) -> see:  https://www.youtube.com/watch?v=1VE64VQLAgQ
Manfred
HughesTooling
Attached is a file where I've imported the stp file, converted to component and rotated the parts so they rotate around the component Z axis. I set up a joint origin for the small gear to rotate around the larger gear Y axis. There are 2 problems though, the offset is wrong so the gears don't mesh correctly so they're not set up correctly in the original stp files and the ratio is 6:1. I've set up a motion link with the 6:1 ratio.
Mark
Mark Hughes
Owner, Hughes Tooling
HughesTooling
@JetForMe If you need to find the offset using the gears you have I did a couple of screencasts here that shows how.
Mark
Mark Hughes
