Fusion Design, Validate & Document
Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Assemblies
1 REPLY 1
amathur
212 Views, 1 Reply
Assemblies
amathur
I am trying to place the sink under the cabinet. I am not able to do this. I tried As-Built Joint and Joint, but cannot do it. Please let me know how to do thisKit Sink.png. Thanks.
Assemblies
1 REPLY 1
TrippyLighting
in reply to: amathur
TrippyLighting
I am assuming you want it centered ?
On the underside of the red part, cnereted on the front lip/edge , add a Joint Origin and pull it to the front/rear offset you need the sink at.
Then you can use a regular joint on the center front edge of the sink and join it to that joint origin.
This would be easier to show in a screen cast, but I am not on my Fusion 360 station at the moment 😉
