Artifact lines in drawings
cdespain
cdespain
There are artifact lines appearing in my drawings.  Also in one case there is missing geometry.  I've included a couple examples.  Does anyone have any ideas where they are coming from?
scott.price
Hi @cdespain,
Thanks for posting - are you seeing these artifacts consistently and in the same places? Are they present in an exported PDF?
If you could send me the .F3Z file from A360 I can take a look and see if I can get a better idea of what the issue is.
To get that you can click on the "i" on the design thumbnail in the data panel on the left of Fusion, and select "Open details in A360"
Once in A360, click to view the design, and then from the "download menu" (downward pointing arrow) in the upper right, Select "Fusion 360 Archive"
You can send that to me at scott.price@autodesk.com - sorry for the trouble and let me know if there's anything I can help with in the meantime.
Best,
Scott
cdespain
The artifacts appear consistently in the same places whenever I create a new drawing from design.  This is a collection of separate files inserted into a new file and assembled with joints.  When i create a drawing form design for the individual files the artifacts do not appear.
scott.price
Thanks for the clarification - did you have any luck outputting the file?
Scott
cdespain
I have emailed the f3z files to you.  They are large, 22MB for both.
