applying a dimension issue
l_dowell1117
l_dowell1117
I'm encountering something that use to work and now isn't. Maybe it's a setting that has changed with an update but we'll see. When I now attempt to apply a dimension to whatever item, if the mouse is hovering over a surface it doesn't apply the dimension put highlights/selects the surface instead when I click the mouse. However, if I move the mouse to a blank area then click, the dimension is visible and gets applied properly. I now may have to zoom out and drag the mouse a significant distance from where I want the dimension just to place it, then drag it to to be close to the item to which it relates. I'm hoping this is just a setting that got toggled and I can set it back, but I have not discerned what it would be. What might I be overlooking?
Lyle D
jhackney1972
If what you are seeing is illustrated in the attached Animated GIF, it is completely normal.  What the application is seeing is a potential surface to index the dimension from.  If this is not what you are experiencing, please attach a video showing your exact issue.
John Hackney, Retired
a.laasW8M6T
I have seen similar recently too and have reported it to Autodesk
Their internal Tracking is FUS-249005
This is not a setting that has been changed as far as I'm aware
Andrew Laas
Senior Machinist, Scott Automation
l_dowell1117
What I'm seeing is similar, but it's happening to the face the circle is drawn on in your example as well as other faces.
l_dowell1117
and to add, this is happening when I try to dimension between two points. I would expect that FS is recognizing that two points are already selected and would not be trying select a new point. Also, the dimension value and lines are disappearing when over a surface but reappear when the mouse moves into a blank area
l_dowell1117
(view in My Videos)
showing what I am experiencing
pkomatlapalli
Hi @l_dowell1117 ,
Did the info from @jhackney1972 and @a.laasW8M6T  help answer your question?
If it did, it’d be great if you could click the "Accept Solution" button so others can easily find it too.
If you’re still needing more help, feel free to share an update here. The community will be happy to jump in with any next steps to help you get where you need to be.
Pavan Kumar | Community Manager
