Apple Computer Purchase, Recommened Specifications, Mac Mini M4
howardkinkade
Message 1 of 35
howardkinkade
Ok it’s time for a new computer.  My current Apple computer is 7+ years old.  The new Mac Mini appears to be the best machine for my needs.  Now, how to most practically spec out the processor and ram.
FUSION WORKS OK’ish for me now.  But, cam tool path generation is often painfully slow, tool path simulation can also be painfully slow. I don’t do much rendering, but will in the future.  The new M4 chip and running Fusion native on it should certainly be a big plus.
Here’s my questions:
* which cpu m4 or m4 pro.  I know single core performance is key for much of Fusion tasks.  Which areas of my use case will benefit from the Pro chip?
* Which part of Fusion would, if any, benefit from the improved GPU’s (i.e. tool path gen, tool path simulations. . .)?
* Ram is always expensive for Apple products.  At what point does more Ram have dimensioning returns?
The new Mac Mini, even in its base configuration, will certainly do me well.  But I’m getting older and don’t like watching my time waste away waiting for tools paths to generate and simulate 😉  I typically keep my computers for 7-10 years, so a little future proofing is always ok.
Please, let me know what parts of Fusuon work flow benefit from the different upgrades available on the new Apple Mac Mini with the M4 chip. Thanks
Replies (34)
Message 2 of 35
TrippyLighting
You may want to check how much memory Fusion and your current models occupy.
If that turns out to be Ok, then a base mac mini should be great.
Message 3 of 35
Leo_Dyn
As far as the GPU goes, to my recollection, and unless something has changed... only rendering is really helped out in Fusion with a GPU.
There are some caveats probably, like having a discrete GPU would help in that it doesn't consume unified memory, rather it has its own, where most (all???) integrated video has to also share the standard system RAM.
Message 4 of 35
TrippyLighting
The GPU is NOT used for rendering, not has that ever been the case.
The GPU is used solely for viewport display
Rendering is CPU only!
Message 5 of 35
Leo_Dyn
Ouch. Saw bad info then, should have known better as it wasn't an official source. But it seemed logical.
Hopefully one day Fusion gets GPU support across the board. For rendering and more importantly to me for the design space, as I have yet to ever render anything ever anyway.
Message 6 of 35
howardkinkade
Good discussion. Thanks!
From what I’m hearing here, CPU performance (single core) and RAM are the key drivers.  The clock speed of the basic Mac Mini vs Mac Mini Pro are the same, but other attributes of these two CPU’s are different.  Which cpu benchmarks would be good indicators of CPU performance that would benefit Fusion performance?  As far as RAM goes, more the better, but at what point is there dimensioning return?  I’m sure that has a lot to do with model sizes.
Message 7 of 35
howardkinkade
I’ve reviewed many M4 vs M4 Pro single core benchmarks.  The performance of the single core CPU’s between these two are nearly identical. So unless I’m missing something, I don’t see any value in the M4 Pro over the standard M4 for Fusion performance.
Trippylighting indicated viewport display may be enhanced with improved graphics. I’m not certain if that could become an issue or not. During what Fusion operations does this become taxed ( I.e. tool path simulation, moving a rendered model on the display . . .). In the future I will likely have two 4K-5K 27” monitors.  Any feedback on how the graphics performance may impact my workflow with an upgrade?  Seems to me this may be unlikely considering much of Fusions performance relies on single core processing.  The multitasking I’d do across the two monitors would be internet, perhaps with a YouTube video.
Trippylighting also suggested checking how much of my current RAM is being utilized.  I now have 40gb of RAM, but on an Intel based machine.  I have not notice whether or not I’ve been limited there, likely not.  If I go standard M4 I’ll probably do 32 gb, if M4 Pro I’ll probably go with the std. 24 gb, 48 gb is a $400 up charge.
Message 8 of 35
howardkinkade
Well it appears I was missing something.  Autodesk recommendations for Fusion states:
“Tool path generation and simulation are multi-threaded operations that will benefit from an increase in core count”
As toolpath generation has been something that slows my workflow considerably, perhaps I would benefit from the added multi core speed of the M4 Pro chip.
Message 9 of 35
TrippyLighting
I did not indicate that. I simply stated that's the only area where Fusion uses the GPU 😉
Message 10 of 35
howardkinkade
Trippylighting, true that, sorry.
Message 11 of 35
antonio_zanella
Community Visitor
Community Visitor
Let's not forget that read and write speed on the internal SSD on the M4 Pro version is double compared to M4. Maybe that can help with general performance on swap (ram) file speed when unified memory is low.
Message 12 of 35
glenQSNHX
Fusion really is the worst when it comes to what they call "mac support". It has previously run like a web app, even on a m2 max with 96g. I just recently upgraded to the m4 max with 128g, however, and it actually runs pretty well, which is suprising. I've developed an unhealthy love/hate relationship with fusion because the experience on the mac is so poor, but for now, I'm satisfied.
It should be noted that I have colleagues that think it runs fine on an m1, but quite frankly, they have low standards. I don't have that kind of patience.
Message 13 of 35
TrippyLighting
Can you provide some models and examples where newer Macs run slow?
The Fusion team is keenly interested in those.
Message 14 of 35
howardkinkade
Well I’ve ordered the Mac Mini, M4 Pro, 48 GB RAM, 1 TB HD.  Perhaps it will be over spec’d, but better over than under (except for cost).  I’ll let everyone know how I feel about the mini after some use.
This thread and my research presents what could be a good opportunity for computer selection for us in the future.  There are many computer reviews with lots of standard benchmark test results and users showing how new computers perform with some random applications.  From those reviews it’s hard to decipher performance for our application, Fusion.  Perhaps we can create some standard models that could be run by users here with their machine configurations to create a reasonable Fusion specific benchmarking tool.  Various aspects of use can be tested consistently from these standard models, such as rendering, large model management, tool path generation, tool simulation. . .
Of course it’s not just the machine, but also how you have setup various parameters in Fusion that can make a performance difference .  We could perhaps ‘pin’ these standard models for user use on their setups and create performance comparisons (hardware and parameter settings). I suspect this may also help debug some user performance issues.
your thoughts?
Message 15 of 35
TrippyLighting
That would indeed be nice!
Message 16 of 35
holmudden
@howardkinkade wrote: "I’ll let everyone know how I feel about the mini after some use."
I am very interested in this as well. I am considering upgrading from my old MacBook Pro 2019 (Intel) to the Mac Mini M4 Pro with the upgraded 14/20-core processor, standard 24GB RAM, and 512GB SSD storage.
I primarily work on CAD designs for clients, as well as 3D printing and extensive CAM/post-processing for my CNC machine. Therefore, performance in these areas is crucial to me.
Message 17 of 35
glenQSNHX
The speed difference across the board will be night and day between those two computers.
Message 18 of 35
glenQSNHX
Message 19 of 35
lazykranch149
Observer
Observer
Did you get Fusion to install on your Mac mini? I just tried to install it and it gets to 98% done and throws an error (see attached screen shot). Any help would be greatly appreciated! Thanks!
Message 20 of 35
lazykranch149
Observer
Observer
By the way, I have the exact Mac mini config that you do.
