joint command
joint command
baloshUSCM9
Message 1 of 17
joint command
baloshUSCM9
Hi. After I use any type of joint command, still I can move each part alone, it is actually didnt joint.
What is the right way to joint?
Replies (16)
Message 2 of 17
g-andresen
please share the file for reply
File > export > save as f3d on local drive > attach to post
günther
Message 3 of 17
baloshUSCM9
Hi
Thank you for your time and help.
Attached please find the file.
1. As you can see, after "rigid group" I can move and separate the
parts.
2. Even that those are components, I can move them only with body as
an object, not with component
I don't understand that, as well
With best regards
Yeshayaou Balosh
Message 4 of 17
swapnil.hamdapureDDSVZ
Hi ,
I don't see any file. Have you attached any file?
Message 5 of 17
mayank.malukani
Hi @baloshUSCM9 ,  Are you moving using the 'Move' command? Or by dragging the component? Because sometimes from the move command, default move type is set to Body move, which is allowed even after rigid group.
Message 6 of 17
baloshUSCM9
Hi
I can only move with copy/move command.
I can't drag it.
But why after rigid command I can separate the components?
Thank you
With best regards
Yeshayaou Balosh
Message 7 of 17
TrippyLighting
Please share a design by exporting the f3d (or f3z) file to your local hard drive and attaching it to a post.
A body is part of a component and can be moved independently of a component.
That can be necessary in multibody components.
Many mechanical designs usually only use one body per component. In those cases you should avoid the move command!
Message 8 of 17
baloshUSCM9
Hi
Thank you
Message 9 of 17
baloshUSCM9
Here attached
Message 10 of 17
laughingcreek
still nothing attached.
Message 11 of 17
g-andresen
did you follow this?  File > export > save as f3d on local drive > attach to post
günther
Message 12 of 17
baloshUSCM9
It is strange
Message 13 of 17
baloshUSCM9
HI
Yes, I did
Can you see the print screen here?
With best regards
Yeshayaou Balosh
Message 14 of 17
laughingcreek
still nothing.  are posting from a PC?
Message 15 of 17
baloshUSCM9
Yes, desktop computer.
I just reinstalled Directs 11, it solved the point to point issue.
With best regards
Yeshayaou Balosh
Message 16 of 17
TheCADWhisperer
@baloshUSCM9
You cannot Attach files by email Reply  -  you must Reply using the web forum Reply.
Message 17 of 17
baloshUSCM9
OK now?
