The offset direction is not always inside on a negative offset value in my experience as seen in this screen grab. The script I used is below and has created an inside offset for circle and an outside offset for just a regular 2 point rectangle. The arrows in the constraint indicate which way the offset was created. The sketch profiles have been created in advance manually as will be the case in my application, if that makes any difference. In further testing it seems to flip the direction of offset if the 2 point rectangle is drawn from bottom left to top right vs top left to bottom right etc. That indicates that the rectangle orientation flips (reversed normal) when drawn from different corners. Maybe you have always drawn the profiles with the same inherent orientation but I recommend you have a play since it is the same result if done manually.
import adsk.core, adsk.fusion, adsk.cam, traceback
def isGroupClosed(curve_list, tol=1e-6😞
if len(curve_list) == 1:
geom = curve_list[0].geometry
if isinstance(geom, adsk.core.Circle3D😞
return True
endpoints = []
for curve in curve_list:
try:
geom = curve.geometry
sp = geom.startPoint
ep = geom.endPoint
pt1 = (round(sp.x, 6), round(sp.y, 6), round(sp.z, 6))
pt2 = (round(ep.x, 6), round(ep.y, 6), round(ep.z, 6))
endpoints.append(pt1)
endpoints.append(pt2)
except:
return False
if not endpoints:
return False
freq = {}
for pt in endpoints:
freq[pt] = freq.get(pt, 0) + 1
for count in freq.values():
if count % 2 != 0:
return False
return True
def run(context😞
ui = None
try:
app = adsk.core.Application.get()
ui = app.userInterface
design = adsk.fusion.Design.cast(app.activeProduct)
if not design:
ui.messageBox('No active Fusion design.', 'Offset Connected Curves')
return
offset_value = -1.0
all_comps = design.allComponents
for comp in all_comps:
for sketch in comp.sketches:
# Access the constraints object: try sketchConstraints first, else geometricConstraints.
constraints = getattr(sketch, 'sketchConstraints', None)
if not constraints:
constraints = sketch.geometricConstraints
allCurves = []
curves = sketch.sketchCurves
for i in range(curves.count😞
try:
curve = curves.item(i)
allCurves.append(curve)
except:
continue
visited = set()
groups = []
for curve in allCurves:
if id(curve) in visited:
continue
try:
connectedCurves = sketch.findConnectedCurves(curve)
except:
continue
group = []
for j in range(connectedCurves.count😞
try:
c = connectedCurves.item(j)
group.append(c)
visited.add(id(c))
except:
continue
groups.append(group)
for group in groups:
if not isGroupClosed(group😞
continue
try:
curve_list = group
val_input = adsk.core.ValueInput.createByReal(offset_value)
offInput = constraints.createOffsetInput(curve_list, val_input)
offInput.isTopologyMatched = False
constraints.addOffset2(offInput)
except:
continue
ui.messageBox('Offset complete')
except:
if ui:
ui.messageBox('Failed:\n{}'.format(traceback.format_exc()))
