Angular Velocity Unit - Fusion Feature Request
MichaelT_123
Advisor Advisor
Message 1 of 1
MichaelT_123
Hi TF360,
I have just stomped... once again... on Parameter Units ... banana peel.
I intended to use the Angular Velocity Unit in the form commonly used in physics: 1/s.
Instead, what was available came from the mechanical sphere of civilisation, ... rpm (revolutions per minute).
Could you please fix this unfortunate omission?
If I don't ask too much, curvature (and a like) unit 1/m would also be a very welcome addition.
I also checked a similar issue as posted years ago:
https://forums.autodesk.com/t5/fusion-design-validate-document/units-in-21st-century/m-p/8975168
Still can find:
bunch (of flowers), bowl (of rice), fistful (of dollars), balloon (of incompetencies) on the Units list.
not to mention the reasonable selection of Area and Volume units.
Regards
MichaelT
@MichaelT_123 -
Your post title was modified to add the product name and version and to increase findability by @CGBenner  - Original: Angular Velocity Unit
MichaelT
Replies (0)
