Analysis bonds using fasteners.
segallyscott
segallyscott
In my assembly I need to do an analysis.  I'm using 4 parts that are bolted together using 5/16-18 hex head bolts.  How do I join the bolts in the assembly so that the analysis accounts for them.  Capture.JPG
dsouzasujay
Hi @segallyscott
From the image i'm not able to clearly see the bolt position.
For simplification, Goto simplify and Remove the BRep solid bolts and create 'Bolt Connector' in Simulation workspace.
If my answer helped, please 'Accept Solution'
Join Fusion Insider
Sujay D'souza
Autodesk Fusion
