All the results of Generative design outcome is failed
b10334039
Observer Observer
b10334039
Observer
Observer
Dear members of Fusion 360 Support:
I am working with a generative design and I am getting a message error telling me that Fusion 360 encountered a problem and failed to generate the outcome generation. Could you please help me to identify what is the problem? Thank you so much for your attention.
Hi @b10334039,
I checked your files in both the files obstacle geometry is not sufficient. Only human body is not sufficiaent to be as obstacle, you need to provide peripharal obstacle geometry on back, left and right.
Starting shape should overlap preserve geometry.
In file panton chair file there is only one preserve geometry, probably that might be causing issue. It is not rule that there should be multiple preserve body but depends on your design it looks that there should be more than one preserve body.
Thank You.
Sagar
b10334039
Observer
Observer
@Anonymous Thank you so much for checking my file!!
I will check all the potential problem that you mentioned. Thank you!!
Hi @b10334039 ,
If this solution works for you, then please mark the solution as accepted.
Thank You.
Sagar
