Aligning Text
Aligning Text
Knipprath
Aligning Text
Knipprath
Quick question: Is there any way to align text to lines?
I'm trying to create a clock face and would like to evenly align the textboxes to their relative positions, but as far as I found, Fusion won't allow me to create symetries or anything alike between the text boxes and other geometry.
neljoshua
You can use sketch constraints (such as colinear) to constrain text boxes to sketch lines.  However, I am unable to dimension to the text box.
I would use construction lines to create the geometry that you want the text to follow and then use constraints to lock the text.
That said, we really should have a way to dimension to text boxes.
__
If this post answered your question, please select "Mark as Solution" in order to help others who may have the same (or a similar) question.
Lenovo Thinkpad P1, 2.70 GHz Intel Xeon, 32.0 GB, Windows 10 Pro
