Aligning Text to center
rob.holmesBKLJD
Message 1 of 32
rob.holmesBKLJD
Hi All,
I might be going mad but I'm trying to align a bit of text to the center of the rectangle. This text will need to be changed a lot so I want the text to remain centered. At the moment it seems you can only align text using the bottom left hand point in Fusion 360. The text has a rectangle around it but when the text is changed its recreated losing any coincident's you manage to set on it.
Any ideas? I'd rather not have to align my text by eye every time.
Thank You
Rob
Replies (31)
Message 21 of 32
etfrench
That's a lot of work.  I'd recommend you watch the screencast I posted earlier 😀
ETFrench
Message 22 of 32
It's insanely frustrating that something so basic eludes such an in-depth program. These workarounds are utterly ridiculous........ brilliantly planned and well thought out, but, ridiculous that it has to be done!  i just scrapped my whole project and did the same project in SW, less than 5 minutes... now i have to import it into fusion to do the stupid G-code.....  really wanted to avoid that and just do it all in F360.   -_-    oh well....
Message 23 of 32
So is an actual fix being worked on at all? Or do we just have to keep this thread alive forever?  At first I thought that I was just too dumb to figure out how to do something as seemingly simple as centering text.  Thankfully it's actually Autodesk...
Message 24 of 32
rkward
Why the workaround Autodesk?  You had all the text alignment features we all needed right there in AutoCAD for 35+ years.  Remember these, [Align/Fit/Center/Middle/Right/TL/TC/TR/ML/MC/MR/BL/BC/BR]??  We certainly do.  Please port these over so that proper alignment with test can be achieved without all the extra work.  I'm not looking for the greatest CAD "experience" but rather the expected and necessary tools like you've provided in the past.
Message 25 of 32
jeff_strater
feedback-on-upcoming-text - request for feedback on upcoming text improvements
Jeff Strater
Engineering Director
Message 26 of 32
rkward
Awesome, very glad to see this!
Message 27 of 32
nelsonhays
This is painful.... Has this been fixed, after 6 years?
Message 28 of 32
g-andresen
Show your use case in a screenshot or screencast and upload the file. Then we can better evaluate the situation.
günther
Message 29 of 32
nelsonhays
Simpler than any specific case, just please add a center grip/point to text boxes and imported .SVG.
Message 30 of 32
chelmite
Observer
Observer
It's been SEVEN YEARS since you posted this, and there's no simple way to align text, unlike every other CAD package, word processor, and graphics program (e.g., Corel).
We need to be able to align text so that our products look good, not clunky.
Message 31 of 32
MichaelT_123
Hi Fellows,
The text object in Fusion has "center/middle" properties in the dialog box for both vertical and horizontal alignment.
Select both (unless other positional tricks are required).
Constrain the text object rectangle (or a line, if the text is on a curve) to your desired location using the usual method; many work here.
... and this is the end ... of the saga.
Regards
MichaelT
MichaelT
Message 32 of 32
rkward
Actually it's the 10 year anniversary of the first post  ...
