Message 1 of 11
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
I've been trying to design a 3d printed diffuser for an LED disc and even though the squares fit the individual LEDs (each LED is 5mm x 5mm), and I have triple checked the correct number of LEDs, the circular pattern just doesn't align when I make it in the sketch. Well, maybe 4 LEDs line up, but then you see progressively the square covers go out of alignment with the LEDs.
This is a reference photo I am using. The view is not perfectly orthograpic, but a good representation. I used the dimensions in the photo:
Here is a screenshot of the model:
I have also attached the Fusion file
