10:08 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
When creating drawings of a tubular framework I need to orientate the individual components to a face or along the tubes axis to make proper orthographic views, but when you make a drawing of the component it displays it in the drawing window along the axis it was create in the design window.
Can you orientate a component/part to a face, sketch, or geometry axis/feature, without using the drawing rotate function, so that one can create proper orthographic views in relation to component geometry with greater speed and accuracy, than noting the design angles and then rotating.
Cheers,
Phil
