Stuck on a workflow? Have a tricky question about a Fusion (formerly Fusion 360) feature? Share your project, tips and tricks, ask questions, and get advice from the community.
Show only
Search instead for
How can I joint this path or what alternatives are there, to avoid manually positioning. The contact point can be whatever, a sketch point, cylinder, etc. Note: this is an oversimplified model. The final part will have curves.
