Addition print setting editor not working properly
04:32 AM
- Mute
- Permalink
- Report
I am using a trial version of Fusion 360 and trying to 3D print a simple geometry.
At this moment, I am trying to set up the print protocol using the Addition menu from the Manufacturing. I followed the steps from this tutorial:
https://help.autodesk.com/view/fusion360/ENU/?guid=Fusion_CAM_tutorials_fff_setup_walkthrough_html
I am stuck at defining the print settings. No matter what print settings I select, if I want to edit them, there are no tabs to go through (see attachment). Also the setup window is missing the edit button of the print settings (see attachment).
The main issue is the print settings editor. Can you tell me why the tabs are missing?
Thank you,
CM
