Adding tabs to a cylinder
cruceru.malin
cruceru.malin
Hello evrybody,
Can someone give an indication on how to add tabs to a cylinder?
In the body below, i want to add 3 square tabs that will extend down and have a hole in them, so i can screw a lid on the cylinder .
davebYYPCU
size and position of the tabs?
size and position of the hole?
Lid and thread?
Not enough info...
mango.freund
hi, @cruceru.malin -- take a look.  -- mango
etfrench
Tabs can be added inside or out.  You can edit your original sketch or you can add a sketch to the top of the cylinder.
ETFrench
cruceru.malin
Hey guys,
I managed to do it by creating a sketch inside the plane of the edge, and drawing some lines. Not pretty, but it works for me.
rushabhthakkar_910
Screencast Video
This is how I Designed it..
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
cruceru.malin
I thought there is a function to add them automatically. but i'm a fusion noob
