T-Spline surface self-intersects issues.
studionomake
Observer Observer
studionomake
Observer
Observer
Hello there, Hopefully someone can help me out with this issue?
At first, I am sorry that my English is not good.
I have uploaded the file I made.
I'd like to convert this Tspline body to Brep body.
I have fixed issues which is red dot warning from error issue.
So there aren't red dot warning on the body but it can not convert to brep still.
I would be really grateful if someone could help me.
Thank you.
Kim
mango.freund
hi @studionomake  -- ich hab auch probleme mit englisch-- aber es gibt den google translator.
also es sind viele fehler im model, die sich nicht sofort zeigen. doppelte flaechen wie die die ich repariert habe.
fehlerflaechen rausloeschen und erneut korrekt fuellen. -- lg mango
studionomake
Observer
Observer
Thank you for reply.
But error is still there.
So I tried to use rhino this time because it's urgent project.
I will learn fusion 360 more. ^^
anyway Thanks for your help.
TrippyLighting
This object does not lend itself well to conversion into a T-Spline model!
While it has been consequently modeled with  quad faces, it was not intended to be used as the the control cage of a Sub-D model.
This is a pure polygon model.
For conversion into a T-Spline  a lot of the edges would have to be creased, but even then problems might persist.
