Acme thread sizes
Acme thread sizes
JFKANSAS
Acme thread sizes
JFKANSAS
What is the process to get new threads added and how long will it take? I think the Acme 3/8 only has 12tpi, I need the option of 10 and 16tpi
etfrench
You also need to specify the class, 2G, 3G, 4G, etc.  This link should have all of the info necessary to create any acme thread: https://www.atimetals.com/products/Documents/TC_AcmeThreadforms.pdf
ETFrench
innovatenate
Autodesk Support
Autodesk Support
Check out the comments in the below IdeaStation post. You can customize an xml file to make unique threads with the thread command inside of Fusion 360.
http://forums.autodesk.com/t5/fusion-360-ideastation-request-a/custom-thread-pitches/idi-p/5392371
I believe there is a possible solution there that may work. Let me know if you have any questions!
Nathan Chandler
Principal Specialist
