- Mute
- Permalink
- Report
I am trying to write a Python Add-In/Script capable of reading parameter values from a document's existing Configuration Table.
So far this is what I've tried:
1. Top level objects: There is no direct API access though the Document or RootComponent objects.
2. Parameters: When accessing Model and User Parameters, only values from the currently selected config are listed
3. UI: Using ui.commandDefinitions I can open the config table, but still cannot find a way to set/retrieve values.
Is there any way to interact with the configuration table through the API?
