A really weird Sweep
- Mute
- Permalink
- Report
I'm trying to make a groove around the main body of a spacecraft model using the Sweep tool.
The Profile is a simple circle, defined in the Groove Tools sketch. The Path (Groove Path 2) is essentially an intersection between the main body and a plane that goes through that position in the model.
I select the Sweep tool and select the profile and path.
And when I select OK it initially seems to look pretty good.
But when I pull back from it, it APPEARS that only a portion of the path has been followed. There's a nice groove for part of the path, but it SEEMS to be blocked at one point.
Pulling back further I see that the path appears to have been followed only partway around the path.
I then select to Save as Mesh and select to preview the mesh, which looks pretty good. It LOOKS as though the groove goes all the way around.
So I bring that mesh up in Slicer and take a close look and the groove does NOT appear to go all the way around, although the part that seemingly didn't become a groove comes up darker. ???
So I look very closely at it in Slicer and it seems that the darker, non-groove part, has fairly large triangles while the good-groove party has super small triangles. What's going on? It's almost as if the Sweep DID go all the way around but for part of the path it didn't sweep with the entire circular Profile. Very Weird.
I've attached the file and it should come up right at the point where I'm doing the Sweep. Hopefully someone will take a look and provide some insight as to what's going on. The pertinent Sweep SHOULD appear in the lower right corner when you bring up the design.
