3D slicing with CURA - path setting
chris_heath01
Message 1 of 8
chris_heath01
Hi - I have not been able to select CURA as the preferred slicer for some time now. This use to work but at some point started producing the error message as seen in the attached screen shot.  I have got around this by using CUSTOM and pointing to the CURA app, which works.  I have done as the error message suggests but to no avail.  However I would like to resolve this and get things working correctly.  What I am trying to figure out is how to modify the path where Fusion 360 looks for CURA to point it to app.  - Thanks for your help.  Regards. Chris
Replies (7)
Message 2 of 8
chris_heath01
Better screen shot - with error message
Message 3 of 8
g-andresen
Since there seem to be recurring problems exporting to Cura, I would right-click on the body in the browser and "Save as Mesh" to export.
Günther
Message 4 of 8
chris_heath01
Thanks Günther,  I have also used this method of creating an STL as well as exporting as an STL.  I just want to resolve the issue with the drop down menu pointing to the a non instance of CURA, I only have one instance on my hard drive so I am not sure where its trying to find the application.  regards. Chris
Message 5 of 8
m.rittweger
Hi, Chris!
Which version of Cura do you use? I used it from 4.81 (methinks) until the actual installed 5.4.0 and have no issues.
Michael
Message 6 of 8
jhackney1972
If your Fusion 360 Save as Mesh -> Cura does not work, use the attached video to create a Custom link to the Cura application.
John Hackney, Retired
Message 7 of 8
chris_heath01
Hi I am using 5.4 but it hasn’t worked for the last few releases.  I have set it up as a custom app and that works.  Just a minor irritation.  Thanks for responding.  Regards Chris.
Message 8 of 8
chris_heath01
Many thanks for your help.  It was just a minor irritation that the ‘CURA’ link doesn’t work.
regards
chris
