3D sketch issues
3D sketch issues
markhD4V8S
Message 1 of 9
3D sketch issues
markhD4V8S
I am trying to make a part that has to about 20mm shell (open on one side) and has a bend.
  I am attempting to use 3D sketch but having difficulty getting the sketch to 'close'.
if I do a really rough one (not going where it really needs to go) I have no trouble.
I assume I am still not connecting a couple lines (ones that go into a different plane)- but cannot seem to make it work
please look at this sketch and help me with the issues.
Replies (8)
Message 2 of 9
kacper.suchomski
Hi
The sketches are missing many constraints.
Go back to the first sketch and make sure it's rigid.
Then apply all necessary constraints to the second sketch; remember to create repeating elements through projection, not drawing.
As a general rule, you should not finish working on a sketch until the padlock icon appears next to it in your browser.
Kacper Suchomski
Message 3 of 9
laughingcreek
if by "close" you mean have a light blue profile, then the problem is you only get that with sketches that are planer.  you're not going to get it with a 3d sketch.
most likely, a 3d sketch isn't the way to go here.  what were your next steps going to be?  the only tool that might work with this sketch would be a surface patch, and it is going to be a warped mess, and not likely the nice part your envisioning.
can you give us some info on what your trying to do?  such as a pic or something?
Message 4 of 9
markhD4V8S
Darn, I made a long reply, then it wanted me to sign in again and lost it.    I will post up a picture of the part I’m making.
Message 5 of 9
markhD4V8S
here is what I'm trying to make. I could get the basic shape pretty close using 'sheet metal' - but of course the fillets etc didn't work.
  I goofed up bending this one- but it does fit well. I would like to try and do it (with support) the proper shape- plus there will be other times I want to do this and I don't have a good idea on how.
 if I could just bend bodies, it would be easy.
thanks for any help.
Message 6 of 9
markhD4V8S
well, after reading responses, and thinking some more. I did a different method.
 I changed the 'main' extrude to more that I wanted in the end. Then made a plane on the angle and location I wanted- split the body and removed the part I didn't want.
then I could hollow it out. still working in it, but looks much more that I want.
still like to hear other methods.
Message 7 of 9
davebYYPCU
Based off your sketches,
Lofted the lower black lines.
I extended the larger panel and Lofted to the first body, trimmed off the excess.
Added a constant Fillet but can be a variable Fillet if that helps.
Pic shows the back lines might have an S bend ??, can't tell.
If it were me, I would sketch on these 2 planes so the single loft could be achieved between them.
3d sketches not required.
Might help...
Message 8 of 9
johnsonshiue
Hi Mark,
Instead of creating the whole model in one operation, I create patch surfaces on individual 2D profiles. Next, stitch the surfaces into a new surface body. Add fillets. Thicken the surface to the desirable thickness and convert it to a Sheet Metal body. The Flat Pattern can be created too.
Many thanks!
Software Test Engineer
Message 9 of 9
markhD4V8S
I do not know how to do most of those - but it would be a good learning opportunity.
