I have a design where I have many instances of a few different components inserted underneath the parent component. I accidentally right-click-selected two of these different components and selected Selectable/Unselectable. If I Undo or try to select the same menu option again, nothing happens.
I realized from this post that the bodies are also set as unselectable. Expanding one of the instances of the component shows that's the case. If I hover over the body for that component, I get the help text "Right click -> Selectable to enable selection"
But nothing I do makes the standard menu options show up. I only get a small subset of the proper right-click menu options for a body (see attached screenshot). I performed this action only on two components of different types, but now every single body inside every single inserted component of these two types is unselectable in my design.
Am I missing something really obvious to re-enable them? I've opened the separate component design itself and there's nothing weird saved back through to the original component.
