3D Sketch -> When to work in Model or Sculpt or Patch
Untill now I worked with sketch in MODEL.
In MODEL in the sketch pallette you can allow to make 3D sketches.
As far as I tried that isn't working
Is this a bug??
going to SCULPT
Here I can create a 3D sketch
Not been in PATCH yet
there you can make a sketch also
Is there an instruction available when to work where??
regards,
Pieter
Never used that feature before. But it works for me. I just tick the corresponding option on. And viola:
TrippyLighting
The sketch engine is the same whether you're in Model, Sculpt or Patchmode.
When sketching by default you start sketching on a plane, so in 2D. However the sketch engine in Fusion 360 is in essence a 3D engine.
If you want to move a sketch element, such as a spline point into the 3D space you'll have to use the move tool.
