Message 1 of 16
I created a sketch in the 24.75 neck blank (sketch9 neck carve copy).
I joined two shapes at the corners on different planes to create a 3d shape i think. I can only select the small plane at the bottom (or top depending on perspective). They are trapezoidal ? in shape.
I want to be able to carve this guitar neck using the 'side faces' of the sketch as 'facets' to remove wood from the body called 'neck taper cut tool' in the top level component.
I'm attaching the .f3d file
