Insert into current design, loses joint functionality
javelin_exile
javelin_exile
So I'm pretty sure this was always working for me before I make many component asemblies that I reuse in other designs. So This time I have a simple test fixture I threw together I wanted to use on a different machine and it seems to be frozen. I have no idea where to look or maybe I've just been at it too long tonight. attached is the assembly I'm importing
jeff_strater
Ground does not come across Insert.  You will need to re-ground "Short gear kicker_Base" after you insert it.
Jeff Strater
Engineering Director
javelin_exile
that was exactly it. thanks!
