- Mute
- Permalink
- Report
Hi folks,
I'm working on a design where I use a 3D Sketch to model the end of a 'fork'.
In the screenshots below, after I've done quite a lot of work in the sketch, you can see that it's fully defined (lock icon on Sketch8 in the browser) :
So far, so good. Now, I need to set two points as the basis for further items. I place these points on 2 segments, and set them in place by defining their distance to some segments. The 1st one goes OK (blue mark), the sketch is not fully defined yet, as the distance for the 2nd (red mark) is not yet set :
This is when things go badly wrong : as I set the distance from the 2nd point to a segment, most of the sketch turns blue, as though most of the constraints had suddenly disappeared. I repeat for clarity : the only change I make from the image above to the one below is setting a distance for a not-yet-fully-defined point :
Does this make any sense ?
This is the second time I build this 3D sketch : the 1st one went OK, but I needed to change a dimension, and Fusion 360 simply refused to do it, claiming it was unable to compute the change. I'm now trying to rebuild another sketch to work around this, and I stumble on another roadblock....
Thank you for your help.
