Hello all,
I am learning F360 as a means tobring my student's models to life with a 3D printer. Sometimes, when we make a model everything will look great on F360, but when I import the design into MeshMixer or my 3D printer software (Zortrax Z-Suite) it shows areas that are too thin to print, so it just treats them as blank spaces. Here is an example of a model that has this problem: https://a360.co/2LF0rLT, specifically, the lamp shade (Body1). To create the .stl, I have been right clicking on the body and selecting save as .stl. I have not changed any of the default settings on .stl conversion.
I have attached images of the default settings and the thickness analysis from MeshMixer that shows the holes. I have also attached the .stl
Thanks!
I'm not seeing any problem with either a new stl generated on my machine or the stl in your post. They both slice with no issues in Slic3r.
p.s. Slic3r reports both are manifold.
ETFrench
An interesting program, I'll try to use it for 3d modeling and continuous carbon fiber 3D printing at work. Several of these printers were recently delivered to us, impressive devices I have to say. Maybe I'll find the same issue as you.
