3D geometry projection issues -
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hi -
Trying to do some relatively simple surface blend patches between to faces to create a smooth transition between surface bodies. PROBLEM: trying to "Include 3D Geometry" from adjacent edges and faces results in super buggy and disconnected corners and lines at a micro level. Extremely frustrating 2 days have been spent trying to accomplish this when other softwares do it in 2 min. I have to manually zoom in and "break link" on each line, then manually connect each corner or intersection in order for the surface patch tool to work properly. AUTODESK - Can you PLEASE improve the surface tools! - Add things like "close loop" for sketch geometry, or automatically close the geometry when projecting the edges from already manifold or solid shapes.
