- Mute
- Permalink
- Report
Hello
I want to make a sort of handle using the pipe command (I used this because I thought this would be possible).
1. So in the screencast below you can see, I want to make the bottem half of the two circles and connect them with another piece of pipe. I cannot select more than 1 curve, so I repeated the command 3 times and joined them. Tried to finish it with a fillet, but it looks hideous. Is there a way you can select more curves/ more dimensions for the pipe command. Or is there a better way to do this?
2. In the second "part" of the screencast (using the pipe command), why can't I make the pipe stop earlier towards the door, so that it doesn't stick out on the other side?
Thanks in advance!
